Inventor Forum
How do changes the icon display in Inventor Professional 2011
4 REPLIES 4
428 Views, 4 Replies
This morning I somehow changed the way the command icons are displayed, so how can I restore the command icons back to the default display. I've tried to figure out where the setting is for the way the icons are displayed, but I haven't been able to reset it back to the default setting.
Here's what the display got changed to, that I want to change back to the default setting.
4 REPLIES 4
Tools>Application Options>Colors
at the bottom of that menu there is a Color Theme.
If you mean that you want the small icons I know in 2012 you can right click on the ribbon and then expand ribbon appearance and then click small, which will give you something like what you showed.
GSE_Dan_A
Right click on Ribbon --> Ribbon Appearance --> Normal (or what ever suits your style)
GSE Consultants Inc.
Windsor, ON. Canada
in reply to: GSE_Dan_A
Thanks very much Dan. Thats was it's, and I set the ribbon display back to the normal setting, which is what I'm used to using. Smiley Happy
Scott
