Inventor Forum
How dim length of arc in IPT sketch?
19 REPLIES 19
Message 1 of 20
1379 Views, 19 Replies
Is it possible to directly measure the length of an arc (if it was
straightened out) other than using a formula with the angle and radius in an
IPT sketch.
Cheers,
--Rob Singlehurst
19 REPLIES 19
Message 2 of 20
Don't worry about this as I worked out a formula so the angle alters to give
me the required length.
Cheers,
--Rob Singlehurst
Message 3 of 20
Vitornis
I was wonder if there was a way to do this. i would like to be able to check and make sure my formula is giving me the correct answer by measuring the length.
Message 4 of 20
ampster401
in reply to: Vitornis
only way I know of is to create a quick idw, place your completed part (or semi-completed part, at least have a feature created using the questionable arc in the sketch) in the idw and apply a arc length dim to it.
ugly but if your are only checking your formula, I would suspect you only need to check it a couple of times until you trust it.
Message 5 of 20
cwhetten
Why not just use the Measure Distance tool?  If it is a non-circular curve, then just select the curve you wish to measure and it will give you the total length.  If it is a circular arc, Inventor will by default try to measure the radius or diameter, but if you use Select Other and flip through a couple of the choices, it will highlight the arc as shown in the pic, and when you select it it will give you the total length.
If you need to use the measurement in another parameter, then a formula is the way to go.
-cwhetten
Message 6 of 20
Dennis_Jeffrey
in reply to: cwhetten
____________________________________________________________
Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert
Autodesk Silver Manufacturing Partner
Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
Message 7 of 20
Vitornis
My problem with that measure tool it that it will select the entire loop. I only want to measure for example in the above picture the ends that form an arc and not include the length of the remainder of the loop.
Plus I'm not always checking the my formula. In many instances i might have a existing part or something and need to add to it  So I want to examine the length of a arc on a loop to be able to compare what stock length of material i could use for it and design around using a stock item as apposed to making something custom.  Custom = more money, more time.
Being Competitive needs to have a balance of less time and money. Having better tools to examine my design can give me a competitive edge.
Message 8 of 20
Vitornis
Also i distrust the measurement tools in Inventor it is far to easy to pick to wrong items or not be able to see if it is giving me the anticipated measurement i want.
Most of the time i end up doing what someone else suggested and make a temporary and making a quick detail drawing to measure these items.
Message 9 of 20
Dennis_Jeffrey
I had absolutely no problems picking only the arc in my active sketch as shown behind the expanded tooltip.
A measured loop can be open as in the arc, or a closed loop.
Message 10 of 20
scottmoyse
in reply to: Dennis_Jeffrey
if you wanted to, you could create a sketch, project the arc, and the use the dimension tool, pick th eend point of the arc, then the center point, then the other end point of the arc, and you will get an arc length dimension.
Very handy for constructing some types of sketches. probably quite useful for some sheet metal base sketches etc..
This answers the question in the title of the thread at least. as opposed to some of the other things that have cropped up.
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Message 11 of 20
Dennis_Jeffrey
in reply to: scottmoyse
Following your example, I get the angle of the arc, not the length.
Here's an easier approach, not needing a second sketch:
1. If the arc is not part of a closed loop, use the measure loop tool to get the arc length.
2. If the arc IS  part of a closed loop,  temporarily make one segment of the loop a construction object, then use the measure loop tool to get the arc length. Convert the construction object back to normal when done.
This method taks a couple seconds and does not require a second sketch.
Message 12 of 20
scottmoyse
http://cadsetterout.com/inventor/inventor-tip-dimension-arcs/
There it is in all its glory. This really depends at what stage of the design process you want to dimension it and use the information. Dennis will likely want the last word?
Scott Moyse
Message 13 of 20
nmunro
Not quite what the OP wanted, the resulting dimension is an angle dim (the three selections define two lines).
https://c3mcad.com
Message 14 of 20
Dennis_Jeffrey
I'm speechless! (that does not happen often!)
Actually, you have been bamboozled. The video link that you provided dimensions the angle, not the length.
The article is incorrect. I live by the slogan - "Believe Nothing Question Everything".
Did you take the time to test out the example in the article? If you had, you would know that it was an angle dimension. If you watch the animation carefully, you will notice that the top point of the arc moves slightly to the right when the 90 value is typed in.
This video should clear it up.  No more words from me, promise.... 🙂
http://teknigroup.com/Videos/2012Q2/dimangle.html
Message 15 of 20
Dennis is absolutely right.
I am afraid that my post is wrong - that technique does show the Included Angle - not the Length.
I was shown that tip by a friend, got over exited and posted it and haven't got around to correcting it.
I will make e it tonight's task!
My apologies to anyone who has been misled.
Paul.
Autodesk Industry Marketing Manager UK D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
Message 16 of 20
scottmoyse
I gracefully apologise! **** you paul munford! lol.
I didnt try it out, i saw the 'style' of the dimension, which matches the arc length style in Acad. I assumed, problem is I didn't make an **** out of you and me, i just made one out of myself!
Lesson learnt!
Scott Moyse
Message 17 of 20
PaulMunford
Here's a new and improved post:
http://cadsetterout.com/inventor/how-to-measure-dimension-and-specify-arc-length-in-sketches/
I hope that it meets approval 🙂
Paul.
Message 18 of 20
Paul & Scott....  sorry for having a bit of fun with the both of you ... 🙂 I'ts not like I've ever made a mistake. (Yeah, Right)
Paul, excellent repost!
Now, you can be on the lookout for my next gaff!
Dennis
Message 19 of 20
drlamb
In 2011, you don't even have to temporarily change to construction lines. Using the distance tool,pick the arc, default is radius,select other shows length.
Donald L.
Inventor Product Design Suite 2016
Windows 7 Professional - 64 bit
HP h8-1380t - i7-3820 @ 3.6 GHz
16 Gb
AMD Radeon HD7950 3Gb
Message 20 of 20
Dennis_Jeffrey
in reply to: drlamb
Correct!
