Dear Sir,
As per file attached named UCS-01, there is by default UCS comes in part & assembly files.
I want the by default position of UCS, as I have attached file named UCS-02.
Pls suggest the settings.
Urmil Bhavsar
Solved by SBix26. Go to Solution.
In your part and assembly templates, orient the coordinate system as you have shown, then right click on the View Cube and select Set Current View as Home > Fit to View.
