Inventor Forum
How can UCS Change
2 REPLIES 2
urmil2229
2128 Views, 2 Replies
How can UCS Change
Dear Sir,
As per file attached named UCS-01, there is by default UCS comes in part & assembly files.
I want the by default position of UCS, as I have attached file named UCS-02.
Pls suggest the settings.
Urmil Bhavsar
Tags (1)
2 REPLIES 2
SBix26
in reply to: urmil2229
In your part and assembly templates, orient the coordinate system as you have shown, then right click on the View Cube and select Set Current View as Home > Fit to View.
urmil2229
Dear sir,
We got success as per your suggestion.
Thanks a lot . . .
urmil bhavsar
