Inventor Forum
How can the output layer for a DXF be controlled 2008
2 REPLIES 2
biskits_n_gravy
223 Views, 2 Replies
I work for a fabricator and we have an old torch that runs on a program with some specific requirements to read a DXF file.  The lines in the DXF must be red and continuous.  I have been experimenting with the save copy as command and haven't found a way to control the output layer. I assume there must be a way to do this since it's a pretty simple idea I just can't find the right setting.  Any help is appreciated.
2 REPLIES 2
japike
in reply to: biskits_n_gravy
We put our parts that need DXFs on a drawing sheet and use the layers there for various things. Then do a "Save Copy As" from there to make the DXF file.
Peace,
Jeff
Inventor 2022
When you RMB on the Flat Pattern (because I think this is only available in the Sheet Metal environment) and select SAVE COPY AS, then select DXF extension, the below window will pop-up allowing you to set layers, colours and visibility.
Brendan Henderson
Web www.blhdrafting.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2016 PDSU SP1 (Build 210), Vault 2016 Professional Update 1 (Build 21.1.4.0)
