Inventor Forum
how can i turn off ucs for printing
3 REPLIES 3
andrew.nao
878 Views, 3 Replies
when i go to print an assembly, the ucs icon is printed also. is there any way to turn that off so i can print a clean picture
3 REPLIES 3
blair
in reply to: andrew.nao
Application Options>Display>Origin 3D Indicator: you will need to de-select both "Show Origin 3D indicator and "Show Origin XZY axis labels".
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
CCarreiras
Hi!
You mean print directly from the work area?
Go to: Tools -> Application Options -> Display, and deselect "Show Origin 3D Indicator"
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
blair
in reply to: blair
You could also use the "Screenshot" addin fro the Autodesk Exchange Apps and use the "Window" Option and select the area that doesn't contain the axis indicator as well. The app also allows you to change the back-ground color so it saves a number of mouse clicks.
Delta Tau Chi ΔΤΧ
