Solved by blair. Go to Solution.
Application Options>Display>Origin 3D Indicator: you will need to de-select both "Show Origin 3D indicator and "Show Origin XZY axis labels".
You could also use the "Screenshot" addin fro the Autodesk Exchange Apps and use the "Window" Option and select the area that doesn't contain the axis indicator as well. The app also allows you to change the back-ground color so it saves a number of mouse clicks.
