@Anonymous wrote:
Could you give me update on thread line visibility?
I am using IV14.
In INV 2014 (and 2015) thread features still do not show up in isometric views.
And what did you want? It has been "only" eight years since the issue was verified and logged by Lisa. Patience, my friend, patience! LOL!
Cheers,
Igor.
@mcgyvr wrote:
@Anonymous wrote:Could you give me update on thread line visibility?
I am using IV14.
Was this problem ever resolved? Threads aren't showing up in my drawings. A screenshot is attached. The smaller end of the piece is threaded. I created it by revolving a sketch in the finished shape and then threading that piece, so I'm wondering if that has something to do with it.
In your case, I think you can do so:
- Right click at base view in IDW
- Hook at Display Thread Features
If only a base view exists, all after that created parallel views show threads.
But no thread display in ISO views. I think, at least the end circle of threads could be done.
Walter
Walter Holzwarth
All I get are lines which look like hidden lines for the walls. Again, screenshot attached.
That is the standard Simplified Representation of threads.
If you want the cosmetic representation you will need to change your view to Shaded.
If you want physical cut thread (Detailed Representation) you will have to model them with the Coil feature (just like the real world).
@Telson.Hadden wrote:
Still no threads in ISO views?
Nope...
Hi Telson,
It is true that the thread is still not shown in iso non-shaded view. Starting from Inventor 2018, you can create model-based definition (3DA) on the part and assembly directly. Would it help?
Many thanks!
