Inventor Forum
How can I show threads on a Inventor drawing without shading the view?
31 REPLIES 31
Message 1 of 32
carbonated
16290 Views, 31 Replies
What is the technique for showing threads on a Inventor drawing? I have an model with the 3D threads shown but when I switch over to the drawing there are no threads shown. I DO NOT want to shade the views.
I activated the Thread Display toggle button in Edit View but still nothing...not even dashed lines or cosmetic threads such as SolidWorks has.
31 REPLIES 31
Message 2 of 32
mcgyvr
in reply to: carbonated
It should show the hidden lines on the shaft..
Even without having to turn on the thread display toggle
for parts..Assemblies you need to turn that option on.
Sounds like you may have a graphics problem if they are not showing up upon base view placement.
Message 3 of 32
R.Corriveau
Is it an ISO view or idw of an ipn?
If so then no. At least not with IV10
Message 4 of 32
carbonated
It's a .idw of an .ipn.
Can I at least show threads of a .ipt on a .idw?
Message 5 of 32
R.Corriveau
Yes but not in an ISO view.
Message 6 of 32
carbonated
That's not good for the assemblers out on the floor that need to see parts as they really are. I will see if SolidWorks can do it tonight just for s**ts and giggles.
Message 7 of 32
This is a personal pet peeve of mine, as I do a lot of iso views
Message 8 of 32
I have verified this problem and this issue has been logged to our
development teams. Thank you for taking the time to report it
Lisa Darrah
Autodesk Inventor Quality Assurance Engineer
wrote in message news:5273790@discussion.autodesk.com...
s**ts and giggles.
Message 9 of 32
Dear Lisa!
It is hardly a new issue. Could you please check with your development
teams?
Thank you,
Igor.
To reply please use igor@iinet.net.au address
"Lisa Darrah(Autodesk)" wrote in message
news:5318490@discussion.autodesk.com...
Lisa Darrah
s**ts and giggles.
Message 10 of 32
tobornot
Could you give me update on thread line visibility?
I am using IV14.
Message 11 of 32
mcgyvr
in reply to: tobornot
I am using IV14.
In INV 2014 (and 2015) thread features still do not show up in isometric views.
Message 12 of 32
IgorMir
in reply to: mcgyvr
And what did you want? It has been "only" eight years since the issue was verified and logged by Lisa. Patience, my friend, patience! LOL!
Cheers,
Igor.
@mcgyvr wrote:
I am using IV14.
Web: www.meqc.com.au
Message 13 of 32
shoopdawoop
in reply to: IgorMir
Was this problem ever resolved?  Threads aren't showing up in my drawings.  A screenshot is attached.  The smaller end of the piece is threaded.  I created it by revolving a sketch in the finished shape and then threading that piece, so I'm wondering if that has something to do with it.
Message 14 of 32
WHolzwarth
in reply to: shoopdawoop
In your case, I think you can do so:
- Right click  at base view in IDW
- Hook at Display Thread Features
If only a base view exists, all after that created parallel views show threads.
But no thread display in ISO views. I think, at least the end circle of threads could be done.
Walter
Walter Holzwarth
Message 15 of 32
shoopdawoop
in reply to: WHolzwarth
All I get are lines which look like hidden lines for the walls.  Again, screenshot attached.
Message 16 of 32
JDMather
That is the standard Simplified Representation of threads.
If you want the cosmetic representation you will need to change your view to Shaded.
If you want physical cut thread (Detailed Representation) you will have to model them with the Coil feature (just like the real world).
Message 17 of 32
shoopdawoop
in reply to: JDMather
Thanks to you both!
Message 18 of 32
Telson.Hadden
Still no threads in ISO views?
Message 19 of 32
mcgyvr
in reply to: Telson.Hadden
Nope... Smiley Sad
Message 20 of 32
 Hi Telson,
It is true that the thread is still not shown in iso non-shaded view. Starting from Inventor 2018, you can create model-based definition (3DA) on the part and assembly directly. Would it help?
Many thanks!
Software Test Engineer
