Inventor General Discussion
Active Contributor
riveter1000
Message 1 of 8 (185 Views)
How can I select these bodies?
185 Views, 7 Replies
03-28-2014 09:06 AM
I am designing some enclosures for PCBs. They come to me as step files with sometimes 400 components. I would like to delete the tiny surface mount components to free up memory. I really only need the PCB and the big components that define the envelope of the enclosure.
My question is how can I select the little ones other than clicking on them one by one? Can I box select or filter them by size like in some 3D applications?
Mark
System Specs:
Dell Precision M6800
CPU Intel I7-4600M
RAM 16 GB
Graphics Nvidia Quadro K5100M
From the multi-solid body part file you can go to Mange Tab > Make Components.  You can then select all your solid body's and choose to convert them to individual .ipt files inserted into a .iam file.
Active Contributor
bgarden
Message 2 of 8 (179 Views)
Re: How can I select these bodies?
03-28-2014 09:10 AM in reply to: riveter1000
Shift + Right Click > Component Size, then choose your percentage of size compared to overall model.  You will see the selected parts highlight as you change percentage.  Once selected you can simply delete.
Hope this helps.
Active Contributor
riveter1000
Message 3 of 8 (165 Views)
03-28-2014 10:03 AM in reply to: bgarden
These are my options when I shift-right click. I don't see a way to select by size.
Mark
System Specs:
CPU Intel I7-4600M
RAM 16 GB
Active Contributor
bgarden
Message 4 of 8 (157 Views)
03-28-2014 10:12 AM in reply to: riveter1000
Sorry, my eyes weren't seeing clearly, I thought you were in an assembly.  I can now see you are in a multiple solid part.
In that case you will just have to multi-select in the browser or graphics window and delete I'm afraid.
(Unless you wanted to convert to an assembly giving you seperate ipt files for each solid body which could then be selected using method in previous response.)
Active Contributor
riveter1000
Message 5 of 8 (152 Views)
03-28-2014 10:23 AM in reply to: bgarden
When you say convert to an assembly, can I convert the part to assembly or do I have to specify that option when I open the step file?
Mark
System Specs:
CPU Intel I7-4600M
RAM 16 GB
Active Contributor
bgarden
Message 6 of 8 (149 Views)
03-28-2014 10:28 AM in reply to: riveter1000
Active Contributor
riveter1000
Message 7 of 8 (144 Views)
03-28-2014 10:35 AM in reply to: bgarden
OK. Thank you.
Mark
System Specs:
CPU Intel I7-4600M
RAM 16 GB
Product Support
4donwan4
Message 8 of 8 (110 Views)
03-31-2014 08:13 AM in reply to: riveter1000
The best suggestion would be the assembly component size option that was given prior. Within the part file you would need to delete individually.
Don
