Inventor Forum
How can I Save to PDF
8 REPLIES 8
Message 1 of 9
Neufeld
264 Views, 8 Replies
Is there a macro that saves or prints a drawing to a PDF with the same name in the same folder?
Thank you,
Juan
8 REPLIES 8
Message 2 of 9
in reply to: Neufeld
Check it out @ cbliss.com
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Thank you,
Juan
Message 3 of 9
I think Kent Kellers site has something that will
allow you to save as a pdf and your normal CAD file at the same time. I can't
remember the name right now. (its KWIK-something though)
Gary Marzetti
Thank you,
Juan
Message 4 of 9
Do a search for One click PDF and hard copy as the
subject, it was started on 12-2 and the program name is KwikPrints
Gary Marzetti
Message 5 of 9
Opp... sorry. You're right, Gary.
the subject, it was started on 12-2 and the program name is
KwikPrints
Gary
Marzetti
Message 6 of 9
KWiKPrints only prints the file, it doesn't save it, and it doesn't have any built in PDF
tools. If you have a PDF writer you can set up KWiKPrints to use it.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Gary_M" wrote in message
news:6E512BB917AA8134A00B46962A17609D@in.WebX.maYIadrTaRb...
> I think Kent Kellers site has something that will allow you to save as a pdf and your
normal CAD file at the same time. I can't remember the name right now. (its KWIK-something
though)
> Gary Marzetti
> "Calimesa" wrote in message
news:9BEA60DAE9A0C3915D014526D8797C86@in.WebX.maYIadrTaRb...
> "Neufeld" wrote in message
news:f1a56cb.-1@WebX.maYIadrTaRb...
> Hello,
same folder?
> Thank you,
> Juan
Message 7 of 9
Here is my setup
KwikPrints
Gary
Marzetti
Message 8 of 9
I wasn't sure - I knew you could set it up to do that. I already had the PDF
Driver so I guess that's why I didn't have a problem.
Gary Marzetti
Message 9 of 9
This is a code I've modified to print a dwf to a
specific folder.  You can easily modify it to a pdf driver.
I have two sets of code for creating a DWF to a
folder.  This one is the current one I use, and it runs off of the
DWFwriter that you can download from the Autodesk webpage.  This was built
using some code I was using to do a SaveAs to create the DWF, so there's some
extra code.
Once the DWFwriter is installed open the
DWFwriter 2 Beta driver and under "Advanced
Properties" -> "DWF
Filename" to select "Don't prompt - use source
filename".  Make this choice
and the "Save As" dialog will not appear
any longer.
When DWFwriter 2 Beta is installed, a string value in the
registry is
created with an empty
value:
HKCU\Software\Autodesk\DWFwriter\2\Publish Directory
Change
this value to your desired target directory (with or without a
trailing \)
and your DWF files will land here.
I have also added code that will write text stating
it's a reference document, print the DWF, and then delete the text.  We do
this for our standards.
Here's the code, take it and copy it into your IDW
template.  Everytime you do a save it will create the DWF to a specified
folder:
Option Explicit
Private obDocument As Document
Public WithEvents DocEvents As
DocumentEvents
Public Sub
AutoSave_Copy_by_Event()
    Set DocEvents =
ThisApplication.ActiveDocument.DocumentEvents
End Sub
Public Sub DocEvents_OnSave(ByVal BeforeOrAfter As
EventTimingEnum, ByVal Context As NameValueMap, HandlingCode As
HandlingCodeEnum)
    SaveAsType "dwf"
End Sub
Private Sub SaveAsType(szFileType As
String)
ThisApplication.SilentOperation = True
Set obDocument =
If obDocument.DocumentType <> 12292
Then
        Exit
Sub
    Else
        Dim
szFileName As String
        Dim
szExtension As String
Dim oPrintMgr As DrawingPrintManager
    ' Create a new sketch on the active
sheet.
    Dim oSketch As DrawingSketch
Set oSketch = obDocument.ActiveSheet.Sketches.Add
    'Name the sketch
    'oSketch.Name =
"DWF"
    ' Open the sketch for edit so
the text boxes can be created.
    ' This is only required for
drawing sketches, not part.
oSketch.Edit
    Dim oTG As
TransientGeometry
    Set oTG =
ThisApplication.TransientGeometry
Create text with simple string as input.  Since this doesn't
use
    ' any text overrides, it will default to the active
text style.
    Dim sText As String
    Dim
oTextBox As TextBox
    sText = "<StyleOverride Bold='True'
FontSize='.4'>REFERENCE ONLY<Br/>NOT A RELEASED
DOCUMENT</StyleOverride>"
    Set oTextBox =
oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(1.5, 3),
sText)
    ' Exit the sketch from the edit
environment.
    oSketch.ExitEdit
 Set oPrintMgr =
ThisApplication.ActiveDocument.PrintManager
    'This is the
name of the DWF printer on my system. Probably should
'Determine this by other means.
'Set the paper size
    Dim oDrawDoc As
DrawingDocument
    Set oDrawDoc =
    Dim
oSheet As Sheet
    Dim oSheetSize As
String
    Set oSheet = oDrawDoc.ActiveSheet
    ' Check to see if a filename is
defined.
    If oSheet.Size = kADrawingSheetSize
Then
        oSheetSize =
kPaperSizeLetter
         '"B
Size"
    ElseIf oSheet.Size = kBDrawingSheetSize
Then
        oSheetSize =
kPaperSize11x17
        '"C
Size"
    ElseIf oSheet.Size = kCDrawingSheetSize
Then
        oSheetSize =
kPaperSizeCustom
          '"D
Size"
    ElseIf oSheet.Size = kDDrawingSheetSize
Then
        oSheetSize =
kPaperSizeCustom
'"Custom Size"
kCustomDrawingSheetSize Then
oSheetSize = kPaperSizeCustom
    End If
    oPrintMgr.Printer = "Autodesk
DWFwriter"
    oPrintMgr.NumberOfCopies =
1
    oPrintMgr.Orientation =
kLandscapeOrientation
    oPrintMgr.ScaleMode =
kPrintBestFitScale
    oPrintMgr.PrintRange =
kPrintAllSheets
    oPrintMgr.PaperSize = oSheetSize
'get the full file name from obDocument
'  szFileName =
obDocument.DisplayName
'Determine the extension of the file
' szExtension = Right(szFileName, 3)
'If the extension is IDW then print a DWF of the file, if not do
nothing
       ' If szExtension = "idw"
Then
szFileName = Left(szFileName, Len(szFileName) - 3) &
szFileType
'szFileName = "I:\Autodesk Inventor\DWF\" &
szFileName
' Call ThisApplication.CommandManager.PostPrivateEvent(kFileNameEvent,
szFileName)
oPrintMgr.SubmitPrint
        'End If
    End
If
oSketch.Delete
ThisApplication.SilentOperation = False
End
Sub
face=Arial size=2>
