Inventor General Discussion
Valued Mentor
Valued Mentor
wh
Message 1 of 4 (325 Views)
How can I measure distance between centers of balls?
325 Views, 3 Replies
06-21-2012 01:51 PM
I'm just playing with a rotor head of a model helicopter (see picture). For proper initial alignment, all main parts shall be setup parallel against one-another. This can be done by aligning the length of the ball linkages.
:smileysad:But therefore I need to know the distance of the ball centers. How can I do that? (STEP file for testing with different Inventor versions is attached).
Thanks for hints
Walter
JDMather
Message 2 of 4 (318 Views)
Re: How can I measure distance between centers of balls?
06-21-2012 02:02 PM in reply to: wh
What if you put Workpoints at the centers of the spheres?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Valued Mentor
Valued Mentor
wh
Message 3 of 4 (307 Views)
06-21-2012 04:04 PM in reply to: JDMather
Hmm, Jeffrey. I'm having difficulties with this task, because I get no response of my selection.
Can you show your file?
Walter
Valued Mentor
Valued Mentor
wh
Message 4 of 4 (281 Views)
06-21-2012 11:40 PM in reply to: wh
Next morning:
- Tried it in an assy with two single parts: Center points could be found
- Tried it in actual assy with many parts: No center points selectable
I've been using adaptivity instead. For constraining, center points are selectable. But not for measuring.
Hoping for the next release
Walter
