Inventor Forum
How can i insert a frame generator in bends????
4 REPLIES 4
Chand777
430 Views, 4 Replies
I want to insert a channel section in bends... but  i cant select that surface to insert frame... So What can i do... Pls suggest me how to do..... Thank you in Advance....
4 REPLIES 4
blair
in reply to: Chand777
The problem with Frame-Gen is that each line segment creates a single part (member) within Frame-Gen. The picture shows 2 different runs. The lower Z is a group of 3 lines and 2 fillets on a sketch. This will produce 5 items within the F-G module (line items 001 to 005).
The upper tube (funny curved run) is a single poly line. Since this is a single line only one tube member (006) was added to the Frame-Gen module.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
JDMather
in reply to: blair
@Blair wrote:
The problem with Frame-Gen is that each line segment creates a single part (member) within Frame-Gen. ....
If you don't select Merge.
If you do select Merge - only one frame member is created.
The CADWhisperer YouTube Channel
blair
in reply to: JDMather
Thanks, learned something new today (don't use F-G alot).
Delta Tau Chi ΔΤΧ
BLHDrafting
in reply to: blair
Merge is great but causes some problems. You can't then use some of the other Frame commands like Trim/Extend, Mitre and such. To acheive these you have to do in place editing of the FG member and scuplt and such. I'm using 2012 and am unsure if this has been fixed in 2013.
Brendan Henderson
Web www.blhdrafting.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2016 PDSU SP1 (Build 210), Vault 2016 Professional Update 1 (Build 21.1.4.0)
