Inventor General Discussion
New Member
0 Kudos
Post 1 of 5
How can i insert a frame generator in bends????
261 Views, 4 Replies
11-16-2012 08:12 PM
I want to insert a channel section in bends... but  i cant select that surface to insert frame... So What can i do... Pls suggest me how to do..... Thank you in Advance....
780 Kudos
Post 2 of 5
Re: How can i insert a frame generator in bends????
11-17-2012 01:50 PM in reply to: Chand777
The problem with Frame-Gen is that each line segment creates a single part (member) within Frame-Gen. The picture shows 2 different runs. The lower Z is a group of 3 lines and 2 fillets on a sketch. This will produce 5 items within the F-G module (line items 001 to 005).
The upper tube (funny curved run) is a single poly line. Since this is a single line only one tube member (006) was added to the Frame-Gen module.
IV2015 SP1-ud2 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-980 Classified - 347.09
SpacePilot Pro 10.2.0 / 17.2.0.11011 / 4.17
Delta Tau Chi ΔΤΧ
2,132 Kudos
Post 3 of 5
11-17-2012 02:12 PM in reply to: blair
blair wrote:
The problem with Frame-Gen is that each line segment creates a single part (member) within Frame-Gen. ....
If you don't select Merge.
If you do select Merge - only one frame member is created.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
780 Kudos
Post 4 of 5
11-17-2012 02:34 PM in reply to: JDMather
Thanks, learned something new today (don't use F-G alot).
Win7-64
Delta Tau Chi ΔΤΧ
Valued Mentor
215 Kudos
Post 5 of 5
11-18-2012 04:23 PM in reply to: blair
Merge is great but causes some problems. You can't then use some of the other Frame commands like Trim/Extend, Mitre and such. To acheive these you have to do in place editing of the FG member and scuplt and such. I'm using 2012 and am unsure if this has been fixed in 2013.
Brendan Henderson
Web www.blh.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2013 PDS Premium SP2 Update 3 (Build 200), Vault 2013 Workgroup Update 2 (Build 17.2.9.0)
