Inventor Forum
how can i get rid of the "extension" line on a diameter dim.
6 REPLIES 6
slphantom
2392 Views, 6 Replies
see attached jpg. I want to know if there is a way to get rid of the "extension line" that the diameter dimension creates?
as you can see it runs over the slots on my detail and looks confusing.
thanks
Scott
win 11 64 bit
Nvida GeForce RTX 4000
Inventor Pro 2023
Space Explorer
6 REPLIES 6
Cadmanto
in reply to: slphantom
Scott,
Try these options when you RC on the diameter dimension.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
slphantom
Yes I know that but what I wanted to know is if there is a way to get rid of that arc it draws that is covering up the slots. just wondering
Scott
win 11 64 bit
Inventor Pro 2023
Space Explorer
Cadmanto
The only options I see you having is to either rotate the dimension around until you see it disapear (which works for me), or edit the dimension style to hide the extention.
Best Regards,
Scott McFadden
BLHDrafting
I was thinking Dim Styles.
Brendan Henderson
Web www.blhdrafting.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2016 PDSU SP1 (Build 210), Vault 2016 Professional Update 1 (Build 21.1.4.0)
okaleja
Currently, extension arcs are drawn automatically when arrowhead point out of the dimensioned arc and can not be turned off.
Oto
Oto Kaleja
Software Engineer
Rkov
in reply to: okaleja
You write "...when arrowhead point out of the dim...". Are you implying that the extension arcs can be turned off when the arrows point IN ? I can't manage to turn my arcs off whether arrows are pointing in or out on my Inventor 2015.
And I would really, really, like to turn these arcs off.
Rkov
