Well this is my problem: I sketched a conic gear tooth that had a particular geometry and was able to generate the surface of the tooth the way i wanted it. But then i had the purpose to convert this group of closed surfaces into a solid extrusion but i can't.
Is there any way i can make this?
I will be pleased if someone can help me.
Greetings to everyone
PD: I attached some views of the tooth it will definetely help 🙂
Solved by SBix26. Go to Solution.
If the surfaces completely enclose a volume, the Sculpt tool will do what you desire.
Sam B
Inventor Professional 2015 SP1 Update 1
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
Thank you very much sbixler this was the solution for my problem.
Best regards.
