Inventor Forum
How can I fix "Minimum Length Violation(Too short to continue)"
7 REPLIES 7
Message 1 of 8
860 Views, 7 Replies
When I use  Derived Route I get  "Minimum Length Violation(Too short to continue)". How can I fix it. Is there any parameter that I can define minimum length.
Thank you
7 REPLIES 7
Message 2 of 8
MariaManuela
In Tube & Pipe Styles dialog box.
Asidek Consultant Specialist
www.asidek.es
Message 3 of 8
I use "ASTM B 88-ASME B16.22 Soldered Copper Tubing" and properties of this tube is attached. Minimum value is zero but still get error
Message 4 of 8
MariaManuela
It is recommended that the minimum segment length is at least 1.5 times Nominal Diameter; otherwise, it is more likely to cause a minimum segment length violation if pipe segments are too small compared to Nominal Diameter.
www.asidek.es
Message 5 of 8
cbenner
Just guessing here without knowing what you are attempting to route, but could your route be causing a conflict with the 2" default bend radius?  If there is not enough space to make the default bend, it could possibly spit out this error.
Message 6 of 8
in reply to: cbenner
My part shape attached. All dimensions are in "mm". When I check everything looks ok but I get error.
Message 7 of 8
cbenner
In they style screen shot, your default bend radius is set to 2 inches.  In your sketch, you have radii of 45.5mm which translates to 1.79 inches.  Not sure if this would cause a minimum length error, but it's something to check.
Message 8 of 8
I tried it but it doesn't work.
