Hi there,
I am trying to draw a series of flow channel (in a row) in a rectangular parallelepiped.
So I sketched a rectangle -> extruded (cut) -> sketched another rectangle -> extruded -> sketched another rectangle inside of one of channel -> extruded, and finally made a flow channel like in attached file.
What I hope to know are :
(1) Is there a way to copy that flow channel? Or sholud I have to do same repeatedly for tens of flow channel?
(2) Is there a way to make a flow channel easily?
Thanks for your helps!
Solved by CCarreiras. Go to Solution.
Using the Rectangular pattern should meet your requirement. 3D Model - >Pattern ->Rectangular
Hi Carlos,
Cool!!!!!! You helped me to solve the problem.
Thank you so much 😄 You are so great.
