Inventor Forum
How can I duplicate a part inside of body?
6 REPLIES 6
hyu36
347 Views, 6 Replies
Hi there,
I am trying to draw a series of flow channel (in a row) in a rectangular parallelepiped.
So I sketched a rectangle -> extruded (cut) -> sketched another rectangle -> extruded -> sketched another rectangle inside of one of channel -> extruded, and finally made a flow channel like in attached file.
What I hope to know are :
(1) Is there a way to copy that flow channel? Or sholud I have to do same repeatedly for tens of flow channel?
(2) Is there a way to make a flow channel easily?
Thanks for your helps!
6 REPLIES 6
MingweiGao
in reply to: hyu36
Using the Rectangular pattern should meet your requirement. 3D Model - >Pattern ->Rectangular
Steven Gao
Sr. SQA Engineer
CCarreiras
in reply to: hyu36
Hi!
You can do that with only one extrusion, and then, Pattern.
Check it.
Regards.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
mrattray
in reply to: hyu36
Welcome to to forums, in the future it would be helpful to those of us helping you if you would post what version of Inventor you're working in. It saves us from wasting the time to download and open your file just to find that it's in a latter version than we're running.
Mike (not Matt) Rattray
hyu36
in reply to: MingweiGao
It was helpful. Thanks 😄
hyu36
in reply to: CCarreiras
Hi Carlos,
Cool!!!!!! You helped me to solve the problem.
Thank you so much 😄 You are so great.
hyu36
in reply to: mrattray
I see.
I'll do that next time 😄
