I've insert a logo in my template. dwg, but I make a mistake: I insert the logo as link.
Now if I open the file in Design Assistant I view the bmp linked to the dwg and when I have to checkin the dwg in Autodesk Vault, I can't to do it because also I delete the logo, it remains the link.
Thank you in advanced.
Best regards.
Solved by Cambo_Slambo. Go to Solution.
I found this on the template's of a company I joined . The only way I worked out how to do it was to open the drawing in AutoCAD and I could see the link in "external Refs" and was able to delete it from there.
