Inventor Forum
how can I create these ribs in fastest way ?
4 REPLIES 4
AlexJones14
431 Views, 4 Replies
 I am trying to create these ribs what is the fastest way to do them?
Thank you for your help
4 REPLIES 4
Sketch lines and use the Rib command.
First thing I noticed is that you have not installed Service Packs 1 & 2.
While I work up a solution file - you might download and install these Service Packs.
Second thing I noticed is that your sketches are not constrained.
Third thing I noticed is that you did not use obvious symmetry about the origin.
I'll be back in a few minutes with solution file.
Find the red End of Part marker and drag down step-by-step to see how the sketches and features were created.
Service Packs
Be sure to disable UAC and anti-virus during install.
Thank you very much for your help TheCADWhisperer , tomorrow morning when I go back to work I will take a look at the files you sent and also do the service pack update and let you know.
Unfortunately I don't have Inventor at home.
Thank you very much TheCadWhisperer, now it all make sense.
appreciate your time
