Inventor Forum
How can I create a flat belt?
6 REPLIES 6
fce
3313 Views, 6 Replies
How can I create a flat belt driven system? The drive system and the flat belt are in the attachments of this message.
What I did until now was to create a part for the belt within the assembly (extrude part). The sketch is depending on the position of the rollers and everything else. Although when I create the belt I can no longer move the system. If I supress the belt, move the system and unsupress the belt, the belts assumes the new positions.
My purpose would be to be able to still get a variable assembly so I could also make a dynamic simulation of the system.
I would really be thankful for some guidance in this.
Best Regards
Tags (2)
6 REPLIES 6
CCarreiras
in reply to: fce
Hi.
You have to guarantee that the belt.ipt is Adaptive in the assembly.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
fce
in reply to: CCarreiras
Hi there CarlosC,
Sorry for the late answer.
I had it already as adaptive. The part is adapative and the sketch and plane too. I send to you a picture with it.
Still I can´t move the system. If I supress the belt, then I can move the system.
Unsupressing the belt again makes it go to the new position.
As you can see in the picture I have the belt part patterned. Although I also tried without the pattern and it didn´t work.
I send to you a picture of the belt and its sketch as well.
Thank you for the help
Best Regards
fce
in reply to: fce
I would like to know what can I do to make it happen.
Best Regards
cwhetten
in reply to: fce
Can you zip and attach your part and assembly files here?
Cameron Whetten
Inventor 2014
fce
in reply to: cwhetten
Hello Cameron Whetten,
I can only send you the part and a schematic to help the understanding of it.
Tell me if you need some other information.
Best Regards
Tags (1)
mcgyvr
in reply to: fce
There are plenty of online tutorials/videos on this.. Did you try searching..
Try first then see if we need to write it all out for you..
Try "Autodesk Inventor adaptive belt" or "Autodesk Inventor adaptive chain"
