Inventor General Discussion
Member
ozertekins
Message 1 of 3 (288 Views)
How can I change workspace adress
288 Views, 2 Replies
11-26-2013 02:10 AM
I'm working on assembly.While I call parts on assembly, I lost a lot of  times to indicate the folder I work on.
Best regards
Hi!
You have to configure one " Project".
Close all your files and then create a new "User Project" pointing your Workspace.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
Distinguished Mentor
ccarreiras
Message 2 of 3 (287 Views)
Re: How can I change workspace adress
11-26-2013 02:17 AM in reply to: ozertekins
Hi!
Regards.
CarlosC
Autodesk Inventor 2014 Certified Professional
Autodesk Factory Design Suite Ultimate 2015
Windows 7 64Bit
Member
ozertekins
Message 3 of 3 (282 Views)
11-26-2013 02:31 AM in reply to: ccarreiras
Thank you very much carlos :smileyhappy:
