Hi all, i'm starting to use inventor but to better understand the infinite functions and capacity of this program i must change language, i'm italian, what should I do or who should I contact?
Thanks to all
There are language packs available for Inventor, which you have to download to get Inventor to change clothes for something like italiano.
If you your reseller is in Italy, he should have sent you the italian version anyways.... so how come you don´t have the language pack in your package?
The default language is english as far as I remember, which you don´t need a language pack to download for.
Here is the language pack download page:
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=18550979&linkID=9242019
For Inventor 2013, what you need to do is download language pack and install it. Then switch the language setting when required.
Details as
http://wikihelp.autodesk.com/Inventor/enu/2013/Help/0000-Installa0/0211-About_La211
Download language pack by the link below
Sam
and i have also searched the italian language pack for inventor 2012 but in the autodesk site there are only the language packs for 2013, and also internet doesn't help.. 😞 can someone help me ?
For 2012 products the language packs are only available through the supscription center as far as I know.
If any Autodesk employee knows better please advise.
Here is a link for Pre-Installation configuration:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16830648&linkID=9240617#section9
Cheers Falk
I have the Inventor version on 2014 in English. I downloaded packages it to have the French language but I do not see where it is necessary to change the language to be able to use the program in French. Could you help me please?
