Inventor Forum
how can I change positional reprasentations in sub assenbly using ilogic?
3 REPLIES 3
354 Views, 3 Replies
Goodmorning,
I'm configuring a band with different supports. Each support is configured with a range; 600-900, 900-1200, 1200-1500 etc. those ranges can be adjust by 50mm and those steps are specified by the pos reps (see attached image).
All the different supports are put in the top assembly and in this assembly I want to switch between the positional representations. I tried to use:
ThisApplication.ActiveDocument.ComponentDefinition.RepresentationsManager.PositionalRepresentations("MyPosRep").Activate
But it won't work. I guess I have to replace "ComponentDefinition" in one way or another to the component name, but I don't know how.
I hope you understand my problem and you are able to help me!
-Mart
3 REPLIES 3
Band = conveyor-belt. 🙂
mpatchus
Make sure the sub assemblies are set to FLEXIBLE or the positional representations can't take effect.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
in reply to: mpatchus
Thank you so much for your reply!
Can I use "ThisApplication.ActiveDocument.ComponentDefinition
.RepresentationsManager.PositionalRepresentations("MyPosRep").Activate" after I've set the sub assembly to flexible?
I'm wondering how Inventor knows which subassembly I want to change without mentioning the name of the sub assembly in the ilogic rule. Or do I need to make sure the name of the pos representation is only used once?
Ik hope you understand!
