Inventor General Discussion
Member
TorTømmervold
Message 11 of 61 (12,910 Views)
Re: Hotfix Kb971138 Download for Vista
04-27-2011 04:28 AM in reply to: NickHambleton5389
Nick.
I am not sure which last disk I should insert.  I did not get any.  All I got was one single exe file which I downloaded from Microsoft.
Bertil
NickHambleton5389
Message 12 of 61 (12,908 Views)
04-27-2011 04:33 AM in reply to: TorTømmervold
When you try installing the hotfix your getting the message to put the last disk in? What kind of media do you have 2012 on? Dvd's, Download, or Flash drive?
When I was installing the hotfix, I had to enter a password for the hotfix. Never seen that before but it worked.
NickHambleton5389
Message 13 of 61 (12,907 Views)
04-27-2011 04:35 AM in reply to: TorTømmervold
It's talking about the last disk in the Dvd set. As in 9 of 9 or whatever the last may be. I had to do that for the update. It asked me for the last disk too, but that was for 2011.
NickHambleton5389
Message 14 of 61 (12,905 Views)
04-27-2011 04:37 AM in reply to: TorTømmervold
http://support.microsoft.com/hotfix/KBHotfix.aspx?kbnum=971138&kbln=en-us
This is the link here to get that hotfix. You will want to check the first one. Then follow step 2. When you get the email for the hotfix, there's a password at the bottom of the email you need to input and you should be good after that.
NickHambleton5389
Message 15 of 61 (12,889 Views)
04-27-2011 06:19 AM in reply to: TorTømmervold
One last thing is to watch where you Unzip the files. I would click browse and unzip it to somewhrere you can find it. I just installed again on another pc in our drafting dept now and it worked fine. 2012 failed to install after 15min. Restarted the install and it's going fine now.
New Member
einstein72
Message 16 of 61 (12,810 Views)
05-03-2011 03:48 AM in reply to: NickHambleton5389
I have downloaded the correct link from microsoft.  I then unzipped the files, but after i told me succesfully unzipped and I ra the program, it gave me a list of programs NOT installed and that was the only one on the list.  How can I fix this?
Vista 32
NickHambleton5389
Message 17 of 61 (12,805 Views)
05-03-2011 04:06 AM in reply to: TorTømmervold
when you click on the unzipped file it should just start installing the hotfix. It shouldn't give you a list to choose from. Once the hotfix is installed, then try installing Inventor again, and it should be able to install. I've done this on 3 pc's here at work and all went fine.
New Member
tswilson4801
Message 18 of 61 (12,456 Views)
05-19-2011 06:22 AM in reply to: NickHambleton5389
Microsoft says that the hotfix password expires every seven days. The password they provided me was more than seven days old and it did not work. Do I just keep trying and hope for the password to be updated?
NickHambleton5389
Message 19 of 61 (12,452 Views)
05-19-2011 06:28 AM in reply to: TorTømmervold
When they send you the hotfix, at the bottom there should be 2 passwords that are good for 24hrs. Try the first one. If that doesn't work, then try the 2nd one.
Did they send you the hotfix? They should not send a email "Today" with a 7 day old password. If that's whats happening, you need to tell them that. I have an email from them that they renamed the file extension, and I can rename it back to what it needs to be and use it any day. If you have no luck with them, I can try to send you this file later if you like.
Hope this helps.
New Member
tswilson4801
Message 20 of 61 (12,444 Views)
05-19-2011 07:52 AM in reply to: TorTømmervold
Using the Microsoft hotfix password with an expiration date of "05/06/11" (perhaps this is June 5 rather than May 6 as I originally thought) the hotfix unzip process started but stalled with an "Error Code 40". This led me to Microsoft's support system which quickly overwhelmed me with digital process instructions. Is there a simpler way to get Inventor 2012 to download to a 32 bit Vista PC?
Post to the Community
New Post
Need installation help?
