Morning,
I received Autodesk Product Design Suite Premium 2012. I'm trying to install and it's saying that I need Hotfix KB971138 for Vista. I can't seem to locate the download link. I found a page that autodesk directs you too, but there's no Link that I can find. Has anyone been through this and found the fix?
System
Core i7 950 @ 4ghz
Asus P6T X58
Corsair Dom 6gig 1600mhz
Evga Gtx 260
Win Vista 64bit Ult
i also need the same hotfix. Got the download.
But where should i need to unzip the downloaded file?
you can extract anywhere
DarrenP
Hi guys, I was able to install and extract the hotfix. But when I run the fix it says "Not applicable to your system" I have the Vista SP2 so I'm not sure whats wrong...... Any help?
You may have a 64bit version of Windows and are trying to install a 32bit patch or the other way around. Right click on "computer" and hit properties. It will show you what version you have there. Hope this helps.
you may also want to ask microsoft support since this is a windows hotfix not an autodesk hotfix
DarrenP
I have provided this in an earlier post in this thread. You can download the 32-bit one here:
is this hotfix that hard to find?
DarrenP
Preaching to the choir, my friend.
Hello guys! I need the KB971138 and when i try to donwload it using the link that microsoft send me in the email (hotfix@microsoft.com) II get the following message:
The resource you are looking for has been removed, had its name changed, or is temporarily unavailable.
And I can´t download it
Can you send me a valid link to download the file?
Thanks!! And sorry for my bad english, i´m from Spain
why are you posting here?
this isn't the microsoft support forum
DarrenP
Sometimes I wonder how many times I will have to repost this...
*sigh*
HOw you did it!? I have the exact same problem, please if you could tell me it would be great, or better if you could email me the answer at luisfer.a.e@gmail.com
Thank you 🙂
Hey Nick, i'm having thesame problem, i went to thesame link but didn't see the Hotfix Kb971138 Download for Vista as informed. How did you find the Hotfix Kb971138?
Once again... the hotfix (sans password) is attached to my message here:
Please download it.
I am having this same problem with Windows Vista 64 bit version. I go to unzip the files that Microsoft has sent me through an email. When it goes to unzip the files it comes up with an error code of 40. All help will be appreciated
