Is there a hot key/ combo of keys to turn off sketchs in an .iam?
Solved by Curtis_Waguespack. Go to Solution.
Aaron,
This is close to what Mike was talking about. Maybe you can tweak it for sketches.
http://inventortrenches.blogspot.com/2013/03/turn-onoff-all-workfeatures-with-ilogic.html
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Thanks, I was just wanting to know if there's a wuick way to turn them on/off besides going into view, kind of like "Alt"+"]" turning off user work planes.
Hi ASchlaack,
In the assembly press the F10 key. This will work the same as "Alt"+"]" for work planes, meaning that it uses the Object Visibility tool to overide the visibility settings at the assembly level.
I hope this helps.
Curtis
Thanks Curtis!
