Im just doing a simple project, and Ive been wondering this for months. How do I apply a montion contraint so that when I use a slider joint, it will stop at a specified point. Can anyone help me? This is I hope a simple task. Please and thank you.
Solved by JDMather. Go to Solution.
Notice that when you create (or edit) the joint that there are two tabs to the dialog box.
Click on the Limits tab.
If you need more sophisticated timing - you might have to create named constraints and Drive or Animate - or go into Tools>Dynamic Simulation.
Can you attach your assembly here?
