Quick question, i have a few holes trueout a disk. (used circular pattern)
Is there a simple way to have them tilt 45° true the disk instead of right true the disk?
Do you want all the holes at 45d, if so, you would need to create a work plane at 45d for your first holes sketch to reside on.
Attach your file here if you can't figure it out.
Here is the file, very simple but i dont know how to create a 45° plane to do this.
Can someone explain this?
This question comes up 2 or 3 times a month.
Simply Revolve-Cut an angled rectangle (image on left).
or
Create a sketch line at desired angle and then create workplane at end of angled line perpendicular to the line by selecting the line and endpoint. Now you have a workplane on which to place sketch point for the angled hole. (image on right)
BTW - you should state when you are not using the latest version of Inventor (2013).
That is why I asked you to attach a trivial file - so that I could see what version you are using.
Interesting , thank you all so far now it just has to face clockwise like this example
Edited your pic
@Anonymous wrote:... so far now it just has to face clockwise like this example
I don't understand this statement. You can have it any angle you want, facing any way you want.
Attach your new attempt here if you haven't found a solution.
I tried to make the holes (strugeling) anyway how can you get them paralel to the border of the circle? or can you just choose the angle afterwords?
I don't understand the latest question.
Can you attach
1. a traditional AutoCAD 2D views?
2. a scanned hand sketch?
3. a software freehand sketch?
4. your latest attempt
..maybe Igor will show his mind reading ability and post the solution.
There are a number of other ways to create the same feature. Instead of point and axis, I could have created a workplane at the end of the sketch line, created a sketch on it and projected the line to a sketch point, then used this for creating the hole. Or I could have created a workplane at 45° through the original sketch point, etc.
It would be an interesting exercise to work out all the different ways to reasonably accomplish this.
