Inventor Forum
Holes in a set of parts
3 REPLIES 3
C.hickey
251 Views, 3 Replies
I have 4 inherited parts that go to an assembly that are not bolted together, so bolted connection won't do. I want to have the same hole placement in all of them but not necessarily the same hole. Is there any way I can make a master template to place the holes and when the template changes the parts change?
Note: iPart would work if I had started from scratch, but I got these parts from someone else's previous work and I need to make changes.
3 REPLIES 3
mdavis22569
in reply to: C.hickey
you could make them table driven via a shared excel file Ilogic or adaptive
Mike Davis
JDMather
As suggested, there are several ways you could do this.
You could create a template part sketch and Derive Component the sketch into all parts.
You could place both parts in a sub-assembly and Project Geometry sketch from one part to the other editing the second part in the context of the assembly (Adaptive techique).
If you run into trouble - can you attach your parts here?
rdyson
in reply to: JDMather
Another way (and possibly easiest giver you have the inherited parts)
Giver part a,b,c & d.
In part a, create a sketch with named dimensions. Mark the dimensions for export.
In parameters, link parts b, c, & d to part a.
Create the same sketch in each using the exported named parameters.
Update part a and the others will update to it.
PDSU 2016
