I have 4 inherited parts that go to an assembly that are not bolted together, so bolted connection won't do. I want to have the same hole placement in all of them but not necessarily the same hole. Is there any way I can make a master template to place the holes and when the template changes the parts change?
Note: iPart would work if I had started from scratch, but I got these parts from someone else's previous work and I need to make changes.
Solved by rdyson. Go to Solution.
As suggested, there are several ways you could do this.
You could create a template part sketch and Derive Component the sketch into all parts.
You could place both parts in a sub-assembly and Project Geometry sketch from one part to the other editing the second part in the context of the assembly (Adaptive techique).
If you run into trouble - can you attach your parts here?
