Is there a way to have the hole type I pick choose the dimension style in an idw?
just wondering.
thanks
Solved by Cadmanto. Go to Solution.
Scott,
Are you talking about when you go to add a hole dimension in the drawing having a way
in that moment to change the dimension style?
If that is the case I am thinking the only way to tackle this is to create an ilogic routine.
If I understand correctly, you're wondering whether the hole types (thru, blind tapped, counterbore blind, etc.) can default to specific, different dimension styles.
Since the Object Default style controls the default style of hole notes, and it currently has no ability to distinguish between hole types, I think Scott's suggestion of iLogic is the way to go.
But this might be worth posting in the Inventor IdeaStation.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
