Inventor General Discussion
0 Kudos
Post 1 of 3
Hole Patching when creating derived part
371 Views, 2 Replies
08-17-2012 12:56 PM
All,
I am trying to patch up a bunch of small holes in a derived assembly. I've tried going to the options tab that comes up when deriving the part/assembly and plugging in values for the range of hole sizes to be patched, but I get no results when clicking ok. I have scaled down the assembly to 1/10 the original size. I set the range of holes to be patched from 0 to 0.25". The diameter of the holes in the assembly are only 0.017" after scaling down. Is there something that I'm missing here?
Thanks in advance for your help!
Inventor Professional 2013
Intel Xeon W3680 @ 3.33Ghz
12GB DDR3 RAM
NVIDIA Quadro 2000 GPU
Windows 7 Professinal 64-bit
I'm not sure if the range criterion is applied before scaling it down or after, but I would imagine before.
Note that the range criterion says (Perimeter).  For a circular hole, this means that it evaluates the circumference of the hole, not the diameter.
Before scaling, the diameter of your hole is 0.17", therefore the circumference of your hole would be 0.17 * pi = 0.53" and this would fall outside of the range you specified (0 - 0.25").
Try adjusting your range, keeping in mind that it is the perimeter that is evaluated.
269 Kudos
Post 2 of 3
Re: Hole Patching when creating derived part
08-17-2012 01:09 PM in reply to: hhls11
0 Kudos
Post 3 of 3
08-17-2012 01:17 PM in reply to: cwhetten
Wow, my bonehead mistake! i completely missed the perimeter part. That did the trick. Thank you much!
12GB DDR3 RAM
