I'm trying to make some holes using "On Point" feature
As seen in the image below I have the axis and points to make it, and suceeded making some (threaded ones).
The points and axis where projected from other part.
But for some reason I can't make it to work in other points, the result for it is in image below
It deletes the entire body and remains only the Hole
Have anyone experienced this before?
Any tips to solve it?
1st question I have is what is with all the axis? You can just project geometry (as long as what you are projecting from is parallel to this surface) to locate the hole points if that is what you are using the axis for.
What version of Inventor and is it up to date with SP's and/or hotfixes?
What options are you using when creating the holes?
Can you post your part/assembly?
Why aren't you just creating a sketch on that face and projecting the geometry from the other part to create the holes?
Or have you tried the bolted connection generator?
I don't know why you have all those axes.. I think you are doing way more work than it needs.
I'm using Inventor 2012 with latest updates
The surface where I'm making the holes it's irregular, that's why I'm projecting axis and point to make it.
These are the options I'm using:
I can't make a sketch on surface since it's irregular
I'll make an assembly with just the parts I need to you understand, I can't post the whole assembly thought
What happens when you do a Manage>Rebuild All on part2?
I didn't understand your workflow - looked more difficult than needed. After I ran into early history tree errors - a moved on to other work.
Maybe I can get back to this one in a couple of weeks once things settle down around here.
If you want the holes to be normal to the surface you can create a plane at an offset from the surface you want the holes on. Create new sketch on it and project the geometry. You create holes on it with the distance needed to reach your part.
I understood that. This is why I said to make a plane parralel with a "section plane" of that part to some offset from that surface and on that plane, not on the surface, you can make the holes. You make the holes not on the irregular plane but on a offseted plane, in such a manner that they will reach your part. This is the only solution I find for drilling holes on a irregular surface. You make a plane not on the surface but above it.
Well if the axis and points are projected geometry aren't they normal to the middle plane? Hence, they are normal to another plane parralel with the middle plane. If you want the holes to be made at different angles, then you must use multiple planes, each at the angle needed. I don't have Inventor at home I might try help you when I'll get to work. But the problem is simple as I get it : if the axis of the holes will be parralel, then they are normal to the same plane/sketch. If they are not, then you'll need multiple planes/sketches.
le : wait! I didn't said to do a plane parralel to the surface. No no. I said do a plane parralel with the cross-section plane of your part. The ones found in "origin" tree.
