Inventor Forum
Hole on Bend
3 REPLIES 3
370 Views, 3 Replies
Hole on Bend
Inventor seems to have a problem with holes that are punched or drilled on
the bend line of a sheet metal part. See the file "HoleInOne.ipt" in
customer files. As you know, if a hole is round before bending, the bend
will deform it. I need to show this in my part.
Any suggestions?
--Randy
3 REPLIES 3
Might Cut accross bend work?
Drew Fulford B.A.Sc. Systems Engineer
Solid Caddgroup Inc. Burlington, Ontario
Tel: (905)331-9670, Fax: (905)331-7280
Corporate: http://www.solidcadcam.com/
Member of the Autodesk Discussion Forum Moderator Program
Visit my MCAD website @ http://www.mymcad.com/
"Randall A. Maxey" wrote in message
news:CF5FF36DD8E48E4BE9293D91561665E6@in.WebX.maYIadrTaRb...
> Any suggestions?
> Thanks,
> --Randy
Drew has it right use a circle and cut across bend won't work on a hole
"Drew Fulford" wrote in message
news:3CD6F0A6988413D23A9B0752037BE4D6@in.WebX.maYIadrTaRb...
on
bend
> > Any suggestions?
> > Thanks,
> > --Randy
jiml
cut across a bend does work here any way
