I think this is a limitation in Inventor, I've learned to live with it. If
it is really important, I'll dimension it using the "D" command, rather than
use the hole note annotation command.
"Kirk A." wrote in message
news:3ffd8a43_2@statler...
> I tried to place a hole note on a chamfered hole. Inventor will not allow
> me to choose the drilled diameter, it picks the chamfered diameter
instead.
> The hole note shown here has the correct dimension, but it is pointing to
> the chamfer diameter, not the drilled diameter as it should be.
> How can I get the arrow to point to the correct diameter?
> Kirk
> Inventor R8
> Dell 4550
> WinXP Pro
> P4, 2.8 Ghz, 1G
> Quadro 900 XGL
> nVidia v6.14.10.4403
> 1280x1024, 32 bit
