Inventor Forum
Hole note manual entry
2 REPLIES 2
CAD-One
256 Views, 2 Replies
In the insert hole note dialog, see how i have to manually key in Dia 9.10 for showing the bolt circle. How can i eliminate manual entry.
C1
Inventor Professional 2020
Vault Professional 2020
AutoCAD 2020
2 REPLIES 2
dan_inv09
in reply to: CAD-One
I right click the hole note and "Text..." then you can access the parameters - name your bolt circle dimension so it's easier to find.
It's not automatic but at least it will change if you change the dimension in the model.
hansome_one
This is a great way to do it.  Yes, it is still just a little manual entry, but if something changes let the software do the work. Here is a screen shot of mine.
Remember, right click "Edit Text", no hole text.  Two different things..
2016 Inventor
W7 - 64 bit
i7 2.6ghz
16g Ram - 3000M
Design Consultant
