I know this is a known bug and has been for a few releases now. Any idea when the heck ADesk is going to address this? This can be very costly if the designer or engineer are not aware of this issue.
In a metric part/drawing, you dimension a hole with the hole note/thread (dimension) command, this hole has a depth to it, the depth will show up in inch units, but shown as metric units. In other words, 0.5" will show up as 0,5mm, not 12,7mm as it should. See attached pic.
As it is we have to edit the hole dimension and manually type in the depth or dimension the holes with the standard linear dimension command which then leads us to having to manually input other info.
Please tell me this has been fixed for Inventor 2009!
