That means one of the two of you get to report it 🙂 No guarantee it will
be seen here.
http://usa.autodesk.com/adsk/item/0,,1073063-123112,00.html
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Jeff Love" wrote in message
news:6952F4390D9FC24F966F57D3EA5778AB@in.WebX.maYIadrTaRb...
> interesting, I bet ADSK will add this to the "wish list". I was able to
> repeat. Autodesk please fix!
> "Matt Stocking" wrote in
message
> news:464568CA885C7BBC1C078413151914D7@in.WebX.maYIadrTaRb...
> > half of this is operator error.
> > say your about to make a hole. if you put something that doesn't work in
> the
> > for a termination dist, say 1..125 it turns red and you fix it.
> > well my partner ignored that and then chose thru all for termination.
the
> > hole fails.
> > it took me 4 new sketches and 20 minutes before i checked the dist
because
> > the hole was supposed to go thru.
> > i thought if you choose thru all, it would ignore whatever is in the
thru
> > dist.
> > not a big thing, just a little annoying.
> > thanks
> > Matt
