Inventor General Discussion
Active Contributor
crev64
Message 1 of 6 (893 Views)
Hole Chart in Drawing Environment
893 Views, 5 Replies
03-19-2013 08:03 AM
I have a lot of scenarios where I have a plate with a bunch of holes (20-50) that I need to do a drawing of. Standard dimensioning is quite cluttered so what I have been doing is creating a hole table. I make a blank table with enough rows for each hole. The columns are hole #, X, Y, and hole type. So I go through and give the X and Y distance from a common point (top left corner) for each hole. This makes it easy to figure out where each hole is when it comes time to drill. I'm current putting these distances in manually which can be error-prone. Is there anyway to have the program fill in these distances and update it whenever there is a change?
Crev64
Autodesk Inventor 2009
Annotate tab/Table panel/Hole table tool.
There is a Hole Table feature built into Inventor to quickly do this for you.
Simply specify the origin and it will complete the X-Y dimensions for you.
Valued Mentor
japike
Message 2 of 6 (891 Views)
Re: Hole Chart in Drawing Environment
03-19-2013 08:08 AM in reply to: crev64
Peace,
Jeff
Inventor 2013
Valued Mentor
mpatchus
Message 3 of 6 (889 Views)
03-19-2013 08:09 AM in reply to: crev64
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
Active Contributor
crev64
Message 4 of 6 (884 Views)
03-19-2013 08:12 AM in reply to: japike
Thanks guys. My life changed today.
Crev64
Valued Mentor
mpatchus
Message 5 of 6 (869 Views)
03-19-2013 09:35 AM in reply to: crev64
Certainly beats the heck out of doing it manually.
Mike Patchus
Valued Contributor
ScottSwens
Message 6 of 6 (506 Views)
03-07-2014 12:44 PM in reply to: crev64
I am trying to add a set of holes to a chart I created. I right click, row, add hole. Pock the holes I wish to add. I now I am to hit 'create' next but that is grayed out.
I even saved my drawing, exited Inventor and reopened.
I have opened up the Edit Hole Table dialog box to change the filters even though they are holes.
Suggestions?
I am on Iv 2013
