Inventor Forum
Hole Chart in Drawing Environment
6 REPLIES 6
crev64
2523 Views, 6 Replies
I have a lot of scenarios where I have a plate with a bunch of holes (20-50) that I need to do a drawing of. Standard dimensioning is quite cluttered so what I have been doing is creating a hole table. I make a blank table with enough rows for each hole. The columns are hole #, X, Y, and hole type. So I go through and give the X and Y distance from a common point (top left corner) for each hole. This makes it easy to figure out where each hole is when it comes time to drill. I'm current putting these distances in manually which can be error-prone. Is there anyway to have the program fill in these distances and update it whenever there is a change?
Crev64
Autodesk Inventor 2015
6 REPLIES 6
japike
in reply to: crev64
Annotate tab/Table panel/Hole table tool.
Peace,
Jeff
Inventor 2022
mpatchus
in reply to: crev64
There is a Hole Table feature built into Inventor to quickly do this for you.
Simply specify the origin and it will complete the X-Y dimensions for you.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
crev64
in reply to: japike
Thanks guys. My life changed today.
Crev64
mpatchus
in reply to: crev64
Certainly beats the heck out of doing it manually.
Inventor 2025 Beta
ScottSwens
in reply to: crev64
I am trying to add a set of holes to a chart I created. I right click, row, add hole. Pock the holes I wish to add. I now I am to hit 'create' next but that is grayed out.
I even saved my drawing, exited Inventor and reopened.
I have opened up the Edit Hole Table dialog box to change the filters even though they are holes.
Suggestions?
I am on Iv 2013
obendov
in reply to: crev64
Hi
I succeded only to create hole chart in the model. Is there a way to import it to the drawing layout as well (the chart that i built seperatly ilayout was built from points and did'nt give the correct values).
