Inventor General Discussion
Active Contributor
0 Kudos
Post 1 of 6
Hole Chart Dim Control
312 Views, 5 Replies
11-28-2012 03:59 PM
Greetings All,
Question:  Is it possible to control the Hole Dimensions called out on the Hole Chart?  As in controling leading/trailing zeros for main hole dim, alt home dim and tolerances?  Can you combine the Main Dim with the Alt dim in a single column, separated with parentheses? (same with tolerance?)
Thanks  :smileyhappy:
Ok after days of struggling.... I found the answer!
For those unknowing:
Right click on the chart and select "Edit Hole Table"
then select "Formatting Table"
In the "Column Settings" box you'll see a column with the heading, "Property"
    Right click on any of the column choices which yields a number value and select "Format Column"
There are two inconspicuous buttons, hold the mouse over them and you'll see "leading zeros" and "trailing zeros"
    Click either one to suppress of unsupress the zeros.
A little challenging to find, but I'm just glad I was finally able to figure it out.
Active Contributor
0 Kudos
Post 2 of 6
Re: Hole Chart Dim Control
11-28-2012 04:39 PM in reply to: sw_convert
I probably should mention that I would normally live with something like this, but the engineering manager hates leading zeros with a passion.
I've looked everywhere I know to look and spent a few hours doing so.  Hole Chart styles manager, Global Settings, Local Settings, up and down the styles manager all followed by a styles update (just in case), and all yielded no results.
Active Contributor
0 Kudos
Post 3 of 6
11-29-2012 11:11 AM in reply to: sw_convert
I really need help on this one guys.  I realize this seems relatively trivial compared to many of the issues that arise on a daily basis.  Even suggestions of where else I can look would be helpful.  I've found nothing on the internet, so this is my last resort for the most part.
Help?
Thanks for ANY help you can offer on this one.  :smileyhappy:
DJD
Active Contributor
0 Kudos
Post 4 of 6
11-30-2012 09:17 AM in reply to: sw_convert
*Pro
284 Kudos
Post 5 of 6
11-30-2012 06:04 PM in reply to: sw_convert
And of course you want to make this change to the Hole Table style in your Style Library (and update your templates) so it applies to all future documents.
Active Contributor
0 Kudos
Post 6 of 6
12-01-2012 12:12 AM in reply to: sbixler
Indeed good sir..... already done!
