Inventor Forum
hole at an angle?
2 REPLIES 2
363 Views, 2 Replies
hole at an angle?
i want to make a hole (drill and tap) at 10 degree angle on a surface. it is possible something like that and how?
thanks,
picozon
2 REPLIES 2
you need to set up a angled workplane. If you don't have all the geometry
you need to make the workplane, you need to use other workfeatures such as
points and axis. Don't forget you can use the origin planes when creating
new planes also.
Kent Keller
Member of the Autodesk Discussion Forum Moderator Program
http://www.MyMcad.com/KWiK/Mcad.htm
"picozon" wrote in message
news:f129c28.-1@WebX.maYIadrTaRb...
possible something like that and how? thanks,
> picozon
Sure, make a workplane at 10deg through where you
want to have the hole intersect the plane (you may have to create some other
work geometry first), put a sketch on that plane and then create the
hole.
Pat
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
want
thanks,
picozon
