The Hole and thread notes command does nothing in a drawing.
I point to a thread hole, the mouse cursor changes to the right simbol but no note is generated.
The assembly is a little big so i cannot post it here, tell me if you have encountered this behaviour
What version/issue of Inventor is this your using?
Can you please post here dataset sample, simplified assembly or just part so we can take a look at this?
Thank you
Stanislav Hutnan
Inventor Development
What is a dataset sample? is it the parts, assembly and drawing themselves?
I closed and opened the drawing and it worked.
But i also encounter a similar problem with the section command. i select the command but cannot select the view, the border isn't shown
Minimum set of file where you are able to reproduce this problem. Ideal if you are able to reproduce this problem with single part then please post the part file here.
Thank you
Stanislav Hutnan
