Inventor Forum
Hole and thread notes doesn't work
5 REPLIES 5
Karol-Or
744 Views, 5 Replies
The Hole and thread notes command does nothing in a drawing.
I point to a thread hole, the mouse cursor changes to the right simbol but no note is generated.
The assembly is a little big so i cannot post it here, tell me if you have encountered this behaviour
5 REPLIES 5
CCarreiras
in reply to: Karol-Or
Hi!
Have you tried doing a drawing only for the part?
Attach here the part.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Paul-Mason
What version/issue of Inventor is this your using?
Inventor 2023 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
t_hutns
Can you please post here dataset sample, simplified assembly or just part so we can take a look at this?
Thank you
Stanislav Hutnan
Inventor Development
Karol-Or
in reply to: t_hutns
What is a dataset sample? is it the parts, assembly and drawing themselves?
I closed and opened the drawing and it worked.
But i also encounter a similar problem with the section command. i select the command but cannot select the view, the border isn't shown
t_hutns
Minimum set of file where you are able to reproduce this problem. Ideal if you are able to reproduce this problem with single part then please post the part file here.
Thank you
Stanislav Hutnan
