Inventor General Discussion
Valued Contributor
trenthoskings
Message 1 of 6 (235 Views)
hinge
235 Views, 5 Replies
11-16-2012 04:59 AM
I`m stuck at this point.I have 2 brackets which they both need cutting so as to create a hinge.The part is sheet metal formed.How does one make the cuts so as to create the hinge and also how can i flatten these 2 pieces please?
Trent
IV-2013
Valued Mentor
japike
Message 2 of 6 (229 Views)
Re: hinge
11-16-2012 05:18 AM in reply to: trenthoskings
I'm not sure how you need these cut but I attached one possibility. Look at the browser to see how it was done. As to the flat, pick a face a click on "Create Flat Pattern".
Peace,
Jeff
Inventor 2013
Valued Contributor
trenthoskings
Message 3 of 6 (207 Views)
Re: hinge
11-16-2012 07:03 AM in reply to: japike
Thanks Jeff
I also did a bit of a search and there is a cut across bend??..not sure how that works but i will try and find more info...thanks for your solution
Trent
Valued Mentor
japike
Message 4 of 6 (204 Views)
Re: hinge
11-16-2012 07:07 AM in reply to: trenthoskings
Can you give a better discription of what you are trying to accomplish?
Peace,
Jeff
Inventor 2013
Valued Contributor
trenthoskings
Message 5 of 6 (198 Views)
Re: hinge
11-16-2012 07:17 AM in reply to: japike
OK...1 bracket will have the middle third cut out and the other hinge will have the 2 outside cut off leaving just a third in the middle....Thank you
Valued Mentor
japike
Message 6 of 6 (188 Views)
Re: hinge
11-16-2012 07:50 AM in reply to: trenthoskings
I think you'll need two different brackets. See attached.
Peace,
Jeff
Inventor 2013
