Inventor Forum
hinge
5 REPLIES 5
trenthoskings
422 Views, 5 Replies
hinge
I`m stuck at this point.I have 2 brackets which they both need cutting so as to create a hinge.The part is sheet metal formed.How does one make the cuts so as to create the hinge and also how can i flatten these 2 pieces please?
Trent
IV-2013
5 REPLIES 5
japike
in reply to: trenthoskings
I'm not sure how you need these cut but I attached one possibility. Look at the browser to see how it was done. As to the flat, pick a face a click on "Create Flat Pattern".
Peace,
Jeff
Inventor 2022
trenthoskings
in reply to: japike
Thanks Jeff
I also did a bit of a search and there is a cut across bend??..not sure how that works but i will try and find more info...thanks for your solution
Trent
japike
Can you give a better discription of what you are trying to accomplish?
Peace,
Jeff
Inventor 2022
trenthoskings
in reply to: japike
OK...1 bracket will have the middle third cut out and the other hinge will have the 2 outside cut off leaving just a third in the middle....Thank you
japike
I think you'll need two different brackets. See attached.
Peace,
Jeff
Inventor 2022
