Good day,
Freshly started on an Inventor 2011 student version, I closed a window which showed the elements of a piece in a hierarchic manner (axis, planes, extrusions, holes,... and sublying scetches).
Does someone know how it can be opened again?
Solved by Cadmanto. Go to Solution.
Solved by -niels-. Go to Solution.
Welcome to the forum.
Make sure the window is not hidden in the background.
Can you post an image of what you are talking about? Not really sure what you are describing.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Yeah, that makes sense, duh!!!
You mean this (and this is 2012)
