Hey Yall,
I am making a multiview drawing with isometric of a certain sheet metal part. Due to manufacturing reasons, they have to make the part longer than necessary to get a bend in it then I will have them shear off the extra. Is there a way I can show the multiview and flat pattern WITH the extra material and show the isometric WITHOUT that extra? In the model I remove the excess with a cut but I don't know how to suppress a feature for one view and not another.
Thanks.
Solved by jletcher. Go to Solution.
Put the extra material in the flat pattern only. this way the part is right and the flat pattern is what you need.
See attached file 2012
